Massive Arcade Button with LED - 100mm
Green
PRODUCT ID: 1188
Description
OMG WATCH OUT! This 100mm diameter arcade button with a 16mm deep plastic base is so massive
and inviting it may collapse upon itself and form a black hole from which not even light can escape! Until
it does, however, it ready for all sorts of pressing and pushing. Science has shown no one can resist
pressing its shiny surface and saying "beep!". We've seen these on some games of skill in arcades, they're
easy to mount on nearly any kind of enclosure. They're not waterproof or weatherproof, so best used
indoors.
This button has a domed green plastic cover with a black retaining ring around it. There's an optional LED
included that will light up the button. The LED has a built in resistor so you can run it up to 12V but given
the massive size and shallow depth of the button, it doesn't illuminate the entire button face evenly. The
button activates a common arcade microswitch (included), the switch contacts are normally open. When the
button is pressed, the contacts close.
Technical Details
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1188”相匹配的价格&库存,您可以联系我们找货
