1192
    ADAFRUIT
    按钮开关 SPST-NO 标准,发光式 前面板安装
1192 数据手册
Large Arcade Button with LED - 60mm White PRODUCT ID: 1192 Description BAM! This 60mm diameter arcade button is large and inviting and ready for all sorts of pressing and pushing. We've seen these on some games of skill in arcades, they're easy to mount on nearly any kind of enclosure. They're not waterproof or weatherproof, so best used indoors. This button has a flat white plastic cover with a black retaining ring around it. There's an optional LED included that will light up the button. The LED has a built in resistor so you can run it up to 12V but given the shallow depth of the button, it doesn't illuminate the entire button face evenly. The button activates a common arcade microswitch (included), the switch contacts are normally open. When the button is pressed, the contacts close.  Technical Details o o o 12mm / .5" height when pressed 15.2mm / .6" height when not pressed 52.5mm / 2.1" long stem with switch installed        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1192”相匹配的价格&库存,您可以联系我们找货
