Large Arcade Button with LED - 60mm Blue
PRODUCT ID: 1194
Description
BAM! This 60mm diameter arcade button is large and inviting and ready for all sorts of pressing and pushing.
We've seen these on some games of skill in arcades, they're easy to mount on nearly any kind of enclosure. They're
not waterproof or weatherproof, so best used indoors.
This button has a flat blue plastic cover with a black retaining ring around it. There's an optional LED included that
will light up the button. The LED has a built in resistor so you can run it up to 12V but given the shallow depth of
the button, it doesn't illuminate the entire button face evenly. The button activates a common arcade microswitch
(included), the switch contacts are normally open. When the button is pressed, the contacts close.
Technical Details
o
o
o
12mm / .5" height when pressed
15.2mm / .6" height when not pressed
52.5mm / 2.1" long stem with switch installed
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1194”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+67.330181+8.14543
