Ratcheting Crimper Pliers - #18-28 AWG
PRODUCT ID: 1213
Make cables and wiring harnesses with ease using smooth ratcheting crimpers. These precision
machined crimpers will turn you into a pro, no more painful struggles with pliers and generic crimpers
that smoosh your contacts so they wont fit properly. Once you've pressed enough, the ratchet releases,
so you know when you've applied enough force.
This model will work best for smaller common connectors, from 0.1mm 2-1.0mm2 / AWG #18-28 - all
those frighteningly small contacts used in fine pitch connectors.
There's three slots and you can sort of eye-ball which one will fit your contact best. Can do
female/socket or male/pin crimps. Check this document for some guidelines on good crimping hygiene.
Technical Details
https://www.adafruit.com/product/1213 1-23-18
很抱歉,暂时无法提供与“1213”相匹配的价格&库存,您可以联系我们找货
