Bluetooth 4.0 USB Module (v2.1 BackCompatible)
PRODUCT ID: 1327
DESCRIPTION
Add Bluetooth capability to your computer super fast with a USB BT 4.0 adapter.
This adapter is backwards compatible with v2.1 and earlier, but also supports the
latest v4.0/Bluetooth Low Energy. Inside lies a CSR8510 Bluetooth USB host.
We've used this with great success on a Windows 7 computer, installing as a
'generic' Bluetooth device, but we expect it to work just fine with any modern
computer as this chipset is very common. So far we've tested it to communicate
with Bluetooth data modules only.
Revision note: As of Friday, August 28th, 2015 these now have unique MAC
addresses! That's great because now you don't have to worry about using two or
more of them at once, handy for people turning these into beacons.
Drivers for CSR Bluetooth modules are built into Windows XP/7/8/10 so you do not
need to install any software or download anything: other bluetooth drivers or
'stacks' such as BlueSoleil are not as good as the Windows stack and will cause
problems. Just plug it in and let windows auto-install the BT driver, it may take a
few minutes! For Linux, use Bluez which works great, our Pi tutorial will be similar
to your favorite distro
http://www.adafruit.com/product/1327
11/12/2015
Technical Details
Dimensions: 18.3mm x 22.1mm x 7.3mm / 0.7" x 0.9" x 0.3"
Weight: 2.1g
Sensitivity: -86dBm
Transmission: +6dBm
CSR8510 A10 Bluetooth USB host
很抱歉,暂时无法提供与“1327”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 7+170.036267+19.08359
