1598
    ADAFRUIT
    拔出工具 用于 IC 插口
1598 数据手册
Professional IC Extraction Tool PRODUCT ID: 1598 Description You take your soldering seriously, so you deserve a serious IC extractor tool. We purposefully never carried the cheap bent-sheet IC extractors, and if you've ever used one you know why. They should call them "IC try-to-extractbut-end-up-bending-half-the-pins-ors" and even with a lot of experience they're just a pain. The Japanese made IC extractor is an exception, it's got ground tips that can wedge in there to lift the chip. Instead of a painful hand-grip, you can use the thumb-wheel to dial in the exact right size.  Technical Details  o o Dimensions: 60x125mm Clamp Dimensions: 5x6mm                               Engineered in NYC Adafruit ® https://www.adafruit.com/product/1598 5‐5‐17
很抱歉,暂时无法提供与“1598”相匹配的价格&库存,您可以联系我们找货
    • 250+130.88997
