1599
    ADAFRUIT
    CUTTER SHEARS OVAL 8.07"
1599 数据手册
Super Scissors - PH-51 PRODUCT ID: 1599 Description Save your scissors! Instead of using your nice shears (and dulling them) or wire cutters (not right for the job) - use these super scissors. They're meant for engineering/maker cutting jobs such as cutting plastic, leather, copper sheet/wire, even coaxial & ribbon cables. There's a notched flat section and a grippy tooth section. Notched (front) section capabilities: o o o o o o Nylon/Kevlar fiber: Various types Copper braided wire: Various types Leather / Cork: Max. 5mm thick Aluminum/Copper sheet: max. 0.5mm thick Plastic plate / PET: max. 1.0mm thick PP / Polycarbonate: Max. 1.2mm thick Toothed (back) section capabilities: o o o o o Aluminum wire: Max. dia. 2mm Rope: Max. dia. 10mm Coaxial cable: 5C(conductor 1mm) PVC cabtire cord: 2 mm2(VCT4) Cotton insulated cord: Various types Technical Details o o o o o Max Dimensions: 205x85mm Blade Dimensions: 58mm Weight: 125g Material : Stainless Steel Hardness: Hardness: HRC56-60                               Engineered in NYC Adafruit ® https://www.adafruit.com/product/1599 6‐23‐17
很抱歉,暂时无法提供与“1599”相匹配的价格&库存,您可以联系我们找货
    • 250+131.16077
