1779
    ADAFRUIT
    74HCT245 LED 驱动器 电源管理 Teensy 平台评估扩展板
1779 数据手册
OctoWS2811 Adapter for Teensy 3.1 Control tons of NeoPixels! PRODUCT ID: 1779 Description  This adapter board connects the Teensy 3.1 to up to thousands of WS2811/WS2812 (a.k.a NeoPixel) and compatible LEDs using the OctoWS2811 Library. It features a 74HCT245 buffer chip and 100 ohm series matching resistors. A CAT6 Ethernet cable is used to connect this board to the LED strips. A CAT6 cable is designed for very high bandwidth, minimal cross-talk between twisted pairs, and 100 ohm impedance, for a very high quality signal. Teensy 3.1 is a small, breadboard-friendly development board designed by Paul Stoffregen and PJRC. Teensy 3.1 brings a low-cost 32 bit ARM Cortex-M4 platform to hobbyists, students and engineers, using an adapted version of the Arduino IDE (Teensyduino) or programming directly in C language. This product does NOT include a Teensy, it's just the adapter!  Technical Details  o o o o o o Four self-threading screws Eight LED outputs Dimensions: 56mm x 34mm x 2mm / 2.2" x 1.3" x .08" Height with Ethernet Outlets: 15mm / 0.6" Weight: 11.1g Teensy 3.1 OctoWS2811 Adaptor https://www.pjrc.com/store/octo28_adaptor.html        Engineered in NYC Adafruit ® https://www.adafruit.com/product/1779 5‐5‐17
很抱歉,暂时无法提供与“1779”相匹配的价格&库存,您可以联系我们找货
