1799
    ADAFRUIT
    3.50mm(0.141",1/8",迷你型插头)- 耳机 电话插头 立体声(4 导体,TRRS) 连接器 焊接孔眼
1799 数据手册
3.5mm (1/8") DIY 4-Pole (TRRS) Plug PRODUCT ID: 1799 Description Repair or design your very own audio cables with these nice and durable phono-jack connectors. This is a great plug to make your own cable with. it's made out of durable metal with a flexible, sturdy spring for strain-relief. Just solder the connector to some wires and you have a DIY audio cable that can rival the best! This item is a 3.5mm TRRS Plug with four poles. TRRS stands for Tip, Ring, Ring, Sleeve. It has four total conductors - three signal and a ground as opposed to a more common stereo jack's two. This connector is most often used in smartphones & cellphones to provide stereo audio and one mic channel. Technical Details Dimensions: o o o o Length of Plug: 16mm / 0.6" Length of Spring: 18mm / 0.7" Length of Enclosure: 23mm / 0.9" Weight: 5.4g                               Engineered in NYC Adafruit ® https://www.adafruit.com/product/1799 6‐23‐17
很抱歉,暂时无法提供与“1799”相匹配的价格&库存,您可以联系我们找货
