Female-Female 2.54 to 2.0mm Jumper Wires x 40
PRODUCT ID: 1919
Description
These jumper wires come with a twist! Instead of going from 0.1"/2.54mm pitch headers to breadboard or
something like that, these are 2.54mm to 2.0mm! Handy for making wire harnesses or jumpering to
annoying 2mm-pitch connectors, these premium female-female jumper wires are around 8" (200mm) long
and come in a 'strip' of 40.
Each pair of wires has 2 pieces of 2.54mm (.1") socket on one end and a single 2x2.00mm (.08") socket on
the other on the other end (1x2mm aren't available). This allows you to connect products with 2.00mm
header spacing like the XBees to a breadboard! Just put extra-long male headers in the breadboard and
connect!
These come in a ribbon strip but you can always pull the ribbon wires off to make individual jumper wires
OR keep them together to make neatly organized wire harnesses.
We suggest picking up some extra-long break-away header pins as well, you can stick those into the
sockets to turn the cables into 2mm socket to 2.54mm male!
Note: The length of the jumper wires is sometimes a bit longer than what is listed.
For best results, when plugging these in a line, have the sides with the 'silver latch bit' sticking out since
that side is a tiny bit wider than 0.1" or .08".
Technical Details
o
o
Length: 200mm (8")
Each wire is 28 AWG (7 strands @ 36 AWG)
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1919”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+94.651431+11.45700
- 25+68.8630625+8.33547
