2073
    ADAFRUIT
    DRILL BIT CARBIDE 0.024"
2073 数据手册
Carbide Square End Mill - 1/8" Shaft 0.6mm Diameter PRODUCT ID: 2073   Description If you've started designing your own PCBs in Eagle or KiCad and want to make your PCB a reality, you may  end up with a CNC mill that can route out PCBs by cutting away the copper trace outlines. We initially  ordered these end mills for our use with an Othermill but they will likely work great in a wide variety of  precision CNC machines.  While we already carry PCB drill bits, end mills are slightly different.  Drill bits can only cut in an axial  direction, meaning in line with the axis of the bit ‐ or up and down on the PCB.  End mills can move in any  direction so you can drill side to side, up and down, etc.  The cutting part is made from tungsten carbide and are suitable for circuit board cutting and probably some  other soft metals and other materials. Each endmill has a high hardness, wear resistance and strength and  they're also super sharp which helps when cutting thru PCBs. These mill bits have a fairly long flute, about  8mm. While this is a bit longer than we are used to, we have found that the bits work quite well and are low  cost enough to replace if they break. Note that even carbide bits will dull eventually when cutting PCBs, we  found we could cut for about 5 hours on each bit before we find they need replacing.    This product comes with one 0.6mm carbide end mill in a protective plastic case.  Technical Details o Total length: 38mm  o 1/8" Shank  o Diameter: 0.6mm                                Engineered in NYC Adafruit ® https://www.adafruit.com/product/2073 7‐18‐17
很抱歉,暂时无法提供与“2073”相匹配的价格&库存,您可以联系我们找货
    • 1+34.53050
