Carbide PCB Drill Bit - 0.9mm
PRODUCT ID: 2120
Description
If you've started designing your own PCBs in Eagle or KiCad and want to make your PCB a reality, you
may start out with an etching system to pattern out traces. But that's only half the job! You'll also need a
way to drill some tiny and accurate holes. That's why we've started selling these PCB drill tips in a variety
of sizes.
They're made from carbide (tungsten steel) and are suitable for circuit boards, electronics, SMT, molding,
metal processing, telecommunications, and other uses. Each drill tip has a high hardness, wear resistance
and strength and they're also super sharp which helps when drilling through PCBs. The drill bits also don't
easily bend or break and come in a nice plastic case to store your tips when you're not using them.
This product comes with one 0.9mm Carbide PCB Drill Bit in a protective plastic case.
Technical Details
o
Total length: 38mm
o
1/8" Shank
o
Diameter: 0.9mm
Engineered in NYC Adafruit ® https://www.adafruit.com/product/2120 6‐26‐17
很抱歉,暂时无法提供与“2120”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+16.591011+2.01240
- 国内价格 香港价格
- 6+16.558856+2.00850
- 国内价格 香港价格
- 1+16.372901+1.98600
