239
    ADAFRUIT
    无焊剂试验电路板 端子条(无框架) 2.20" ~ 7.00"(55.9mm ~ 177.8mm)
239 数据手册
Full sized breadboard PRODUCT ID: 239  Description This is a 'full-size' breadboard, 830 tie points. Good for small and medium projects. It's 2.2" x 7" (5.5 cm x 17 cm) with a standard double-strip in the middle and two power rails on both sides. You can pull the power rails off easily to make the breadboard as thin as 1.4" (3.5cm). You can also "snap" these breadboards together either way to make longer and/or wider breadboards. The back is made of foam double-sided tape, if you remove the protective paper you can attach it to a flat clean surface.  Technical Details Details: o o Dimensions: 2.2" x 7" x 0.4" (5.5 cm x 17 cm x 1cm) Weight: 83.7g / 3oz                                 Engineered in NYC Adafruit ® https://www.adafruit.com/product/239 5‐5‐17
很抱歉,暂时无法提供与“239”相匹配的价格&库存,您可以联系我们找货
