2523
    ADAFRUIT
    STARTER PACK UFL SHIELD
2523 数据手册
Adafruit FONA 800 uFL Shield Starter Pack RODUCT ID: 2523        Description Build your own cellular project and get off the grid with FONA. This pack comes with an uFL‐ antenna type FONA and paired with hand‐picked accessories. It's the Adafruit FONA 800 Shield  Starter Pack.  The FONA 800 Shield, is an adorable all‐in‐one cellular phone shield that lets you add voice, text,  SMS and data to your project in an easy to use pluggable shield.  This shield fits on top of any classic Arduino or compatible, and packs a surprising amount of  technology into it's little frame. At the heart is a GSM cellular module (we use the latest SIM800)  the size of a postage stamp. This module can do just about everything. This starter pack has a  FONA 800 Shield. For the Breakout uFL version, click here! And for the Breakout SMA version  click here!  o o o o o o o Quad‐band 850/900/1800/1900MHz ‐ connect onto any global GSM network with any  2G SIM (in the USA, T‐Mobile is suggested)  Make and receive voice calls using a headset OR an external 8Ω speaker + electret  microphone  Send and receive SMS messages  Send and receive GPRS data (TCP/IP, HTTP, etc.)  Scan and receive FM radio broadcasts (yeah, we don't exactly know why this was  included but it works really well)  PWM/Buzzer vibrational motor control  AT command interface with "auto baud" detection  Sounds delicious, right? So we plated this fine module onto a shield with all the extras you need  to make your next project shine.  o o o o o o o o Onboard LiPoly battery charging circuitry so you can take your project on the go. Use  any 500mAh+ LiPoly or LiIon battery and recharge via the Arduino when necessary. Two  LEDs let you know when its charging and done. You can then flip the switch and use the  battery to run your circuit!  Standard 4‐pole TRRS headphone jack. Use any 'Android' or 'iPhone'‐compatible headset  with mic  Breakouts for external 8Ω speaker and electret mic if you don't want to use a  headphone  Level shifting circuitry to make it Arduino‐safe  Vibrational motor (buzzer) driver so you can have noiseless notifications  uFL connection for external antenna  Indicator LEDs for power and network connectivity  Any standard 2G SIM slides into a secure connector  On its own, this shield can't do anything. It requires a microcontroller like an Arduino to drive it!  Microcontroller not included! We recommend an Arduino UNO to go along SIM card not  included! If you are in the USA, we recommend TING  This Pack Contains:  o o o o o o o 1x Adafruit FONA 800 Shield ‐ Voice/Data Cellular GSM for Arduino  1x Slim Sticker‐type GSM/Cellular Quad‐Band Antenna ‐ 3dBi uFL  1x Lithium Ion Polymer Battery ‐ 3.7v 1200mAh  1x Mini Metal Speaker w/ Wires ‐ 8 ohm 0.5W  1x Wired Miniature Electret Microphone  1x Cell‐phone TRRS Headset ‐ Earbud Headphones w/ Microphone  1x Vibrating Mini Motor Disc   Technical Details This Pack Contains:  o o o o o o o 1x Slim Sticker‐type GSM/Cellular Quad‐Band Antenna ‐ 3dBi uFL  1x Mini Metal Speaker w/ Wires ‐ 8 ohm 0.5W  1x Vibrating Mini Motor Disc  1x Adafruit FONA 800 Shield ‐ Voice/Data Cellular GSM for Arduino  1x Lithium Ion Polymer Battery ‐ 3.7v 1200mAh  1x Wired Miniature Electret Microphone  1x Cell‐phone TRRS Headset ‐ Earbud Headphones w/ Microphone     Datasheets: o o o o o o o o o o o o FCC TCB BT  https://cdn‐shop.adafruit.com/datasheets/SIM800_FCC_TCB_BT.pdf  R&TTE Statement of Opinion  https://cdn‐shop.adafruit.com/datasheets/SIM800_CE.pdf  FCC Part 15B Test Report  https://cdn‐shop.adafruit.com/datasheets/SIM800_FCC_Part15.pdf  FCC Part 15C Test Report  https://cdn‐shop.adafruit.com/datasheets/SIM800_FCC_Part15_BT.pdf  FCC RF Test Report  https://cdn‐shop.adafruit.com/datasheets/SIM800_FCC_Report.pdf  FCC TCB  https://cdn‐shop.adafruit.com/datasheets/SIM800_FCC_TCB.pdf        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2523”相匹配的价格&库存,您可以联系我们找货
    • 1+115.37712
