2912
    ADAFRUIT
    适配器连接器 端子块,8 针 至 模块,母插孔,8p8c(RJ45) 黑色
2912 数据手册
Ethernet RJ45 Female Socket Push-Terminal Block PRODUCT ID: 2912 Description   If you need to connect an RJ45 cable (a.k.a Ethernet) to a board that doesn't have an Ethernet jack - this adapter will come in very handy! No soldering required. Just push the little buttons and slide in your stranded or solid-core wire. Note that these aren't recommended for actual Ethernet traffic, especially long term...but for basic power/data distribution, RJ45's are great! This is the Ethernet (RJ45) Female Jack Push-Terminal Block. There is a standard RJ45 Ethernet jack on one end, and a push terminal block on the other. We also have a (matching) Ethernet Male Plug Terminal Block. Technical Details  o o Length (end to end): 36mm / 1.4" Weight: 20.6g                                 Engineered in NYC Adafruit ® https://www.adafruit.com/product/2912 5‐17‐17
很抱歉,暂时无法提供与“2912”相匹配的价格&库存,您可以联系我们找货
