Ethernet RJ45 Male Plug Terminal Block
Product ID: 2913
Description
If you need to connect an RJ45 cable (a.k.a Ethernet) to a board that with an
Ethernet Jack - this adapter will come in very handy! No soldering required. Just
use a slim screwdriver to open up the terminal blocks, slide in your stranded or
solid-core wire and re-tighten. Note that these aren't recommended for actual
Ethernet traffic, especially long term...but for basic power/data distribution,
RJ45's are great!
This is the Ethernet (RJ45) Male Plug Terminal Block. There is a standard RJ45
Ethernet plug on one end, and a screw terminal block on the other.
Please note these are wired using the '468b' connection scheme: RJ45 1-2-3-45-6-7-8 connects to Screws 3-4-5-2-1-6-7-8
We also have a (matching) Ethernet Female Jack Terminal Block.
New Products video link
https://youtu.be/3HfHwCfVjLo
Technical Details
Length (end to end): 53.9mm / 2.12"
Weight: 17.7g
Terminal pitch: 5mm
Wire gauge: 26-16AWG
https://www.adafruit.com/product/2913/11-23-21
很抱歉,暂时无法提供与“2913”相匹配的价格&库存,您可以联系我们找货
