2914
    ADAFRUIT
    适配器连接器 立体声耳机插孔,3.50mm(0.141",1/8") 至 端接块,4 位置 黑色,绿色
2914 数据手册
      3.5mm (1/8") 4-Pole (TRRS) Audio Plug Terminal Block PRODUCT ID: 2914         Description One truth about working with audio is you always need the cable or adapter you don't have in your  toolbox. That's why we love these terminal‐block audio connectors so much. No soldering required!  Use stranded or solid core wire and a small screw driver to create custom wiring jigs.  This is the 3.5mm (1/8") 4‐Pole (TRRS) Audio Plug Terminal Block. TRRS stands for Tip, Ring, Ring,  Sleeve. It has four total conductors ‐ three signal and a ground as opposed to a more common stereo  jack's two. This connector is most often used in smartphones & cellphones to provide stereo audio and  one mic channel. On a Raspberry Pi the extra connector is used for composite video.  Note that the green block labels it as GND‐blank‐Right‐Left which is the most commonly used order.  However, it would be more technically correct to just label it Sleeve‐Ring‐Ring‐Tip: goes in the same  order as the four contacts on the plug.  May come with nickle or gold plated contacts.  We also have a (matching) 4‐Pole Audio Jack Terminal Block!  Technical Details Note: As of Wednesday, April 20th 2016, this product is now gold plated instead of nickel plated.  o o Length (end to end): 40mm / 1.57"  Weight: 6.5g        https://www.adafruit.com/product/2914 7‐26‐17
很抱歉,暂时无法提供与“2914”相匹配的价格&库存,您可以联系我们找货
