3031
    ADAFRUIT
    MICROSOFT AZURE IOT STARTER KIT
3031 数据手册
Microsoft Azure IoT Starter Kit w/ Adafruit Feather M0 WiFi PRODUCT ID: 3031  Description In collaboration with Microsoft, Adafruit's releasing IoT Starter Kits with boards, sensors, and components that are 'Azure Certified for IoT.' Azure is Microsoft's cloud solution for IoT projects. Azure is a comprehensive and flexible program from the Microsoft team that they're extending into the open source hardware world. This starter kit includes a pre-soldered Adafruit Feather M0 WiFi with stacking headers, a FeatherWing OLED, and some sensors and components to get you started on your IoT journey. Feather is a development board from Adafruit that, like its namesake, is thin, light and lets you fly. We designed Feather to be a new standard for portable microcontroller cores. The Adafruit Feather M0 WiFi with ATWINC1500 is our take on an 'all-in-one' Arduino compatible and high speed, reliable WiFi board with built in USB and battery charging. The FeatherWing OLED adds a 128x32 monochrome OLED plus 3-user buttons to the main Feather Board. And for more information on how to run Azure, check out the Microsoft Azure site! https://azure.microsoft.com/en-us/develop/iot/starter-kits/ You can also DIY your own t-shirt - as seen in the Microsoft /Build Keynote with our flexible matrix! Note: As of April 18th, 2016 this product is no longer shipping with a Lithium Ion Battery. You can add one to this product separately. This kit includes: o o o o o o o o o o o o 1x Assembled Adafruit Feather M0 WiFi w/ Feather Stacking Headers 1x FeatherWing OLED - 128x32 OLED Add-on 1x Assembled BME280 I2C or SPI Temperature/Humidity/Pressure Sensor 1x Micro Servo 1x PIR (motion) Sensor 1x Fast Vibration Switch 1x Magnetic Contact Switch (door sensor) 1x Full-sized Breadboard 1x Assembled TCS34725 RGB Color Sensor 1x Premium Male/Male Jumper Wires - 20 x 6" 1x Premium Male/Male Jumper Wires - 20 x 3" 1x USB Cable - A/Micro B Component bag containing: o o o o o o o o o o 3x 12mm Tactile Switches 1x Breadboard Trim Potentiometer 10K 1x Diffused 10mm Green LED 1x Diffused 10mm Red LED 5x 10K 5% 1/4W Resistor 5x 560 Ohm 5% 1/4W Resistor 1x Piezo Buzzer 1x Photo Cell Light Sensor 1x Diffused RGB (tri-color) LED 1x Breadboard-friendly SPDT Slide Switch                                 Engineered in NYC Adafruit ® https://www.adafruit.com/product/3031 5‐5‐17
很抱歉,暂时无法提供与“3031”相匹配的价格&库存,您可以联系我们找货
