3217
    ADAFRUIT
    MAKER PASTE LEAD-FREE PROTOTYPIN
3217 数据手册
        Maker Paste - Low Temperature LeadFree Prototyping Solder Paste PRODUCT ID: 3217   Does your prototyping project require soldering? Are you looking for something other than your usual run-o'-the-mill solder wire? Look no further! This high quality, low cost, adorably packaged Lead-Free Prototyping Solder Paste from IC Breakout will provide strong, flux-aided conductive bonds for your board. This paste is now reformulated to melt at very low temperatures - only 140 °C! Since it’s premixed, all you need to do is screw on the self-piercing cap, squeeze the paste onto your solder pads, and heat it up using a soldering iron, oven, or any other thermal source to reach the reflow temperature of 140 °C (284 °F). Once liquidus, remove your heat source and let it cool. The lead free metal content is a mix of Bismuth, Tin and Silver. The mix is a eutectic solder, meaning that it’s either going to be a solid or liquid during reflow; not something in between. Features:  Lead free  No clean-up  Clear residue  Premixed, ready to use  Low temperature use Specifications:  Bi57 42Sn Ag1  ~10 grams  Liquidus at 140 °C (284 °F) TECHNICAL DETAILS Product Dimensions: 70.0mm x 16.0mm x 10.2mm / 2.8" x 0.6" x 0.4" Product Weight: 9.6g / 0.3oz                                                             https://www.adafruit.com/product/3217 7‐13‐18
很抱歉,暂时无法提供与“3217”相匹配的价格&库存,您可以联系我们找货
