3242
    ADAFRUIT
    - ATmega32U4,nRF51822 收发器; Bluetooth® Smart 4.x Low Energy(BLE) 2.4GHz 评估板
3242 数据手册
    Adafruit Feather 32u4 Bluefruit LE with Stacking Headers - Assembled PRODUCT ID: 3242       Description This is the Adafruit Feather 32u4 Bluefruit ‐ our take on an 'all‐in‐one' Arduino‐compatible + Bluetooth  Low Energy with built in USB and battery charging. It's an Adafruit Feather 32u4 with a BTLE module,  ready to rock!  Feather is the new development board from Adafruit, and like its namesake it is thin, light, and lets you  fly! We designed Feather to be a new standard for portable microcontroller cores. We have other  boards in the Feather family, check'em out here.  Bluetooth Low Energy is the hottest new low‐power, 2.4GHz spectrum wireless protocol. In particular,  it's the only wireless protocol that you can use with iOS without needing special certification, and it's  supported by all modern smart phones. This makes it excellent for use in portable projects that will  make use of an iOS or Android phone or tablet. It also is supported in Mac OS X and Windows 8+.  At the Feather 32u4's heart is at ATmega32u4 clocked at 8 MHz and at 3.3V logic, a chip setup we've  had tons of experience with as it's the same as the Flora. This chip has 32K of flash and 2K of RAM, with  built in USB so not only does it have a USB‐to‐Serial program & debug capability built in with no need  for an FTDI‐like chip, it can also act like a mouse, keyboard, USB MIDI device, etc.  To make it easy to use for portable projects, we added a connector for any of our 3.7V Lithium polymer  batteries and built in battery charging. You don't need a battery, it will run just fine straight from the  micro USB connector. But, if you do have a battery, you can take it on the go, then plug in the USB to  recharge. The Feather will automatically switch over to USB power when it's available. We also tied the  battery through a divider to an analog pin, so you can measure and monitor the battery voltage to  detect when you need a recharge.  This Adafruit Feather 32u4 Bluefruit comes assembled with Feather Stacking Headers.  Here are some handy specs! Like all Feather 32u4's you get:  o o o o o o o o o o o o o o Measures 2.0" x 0.9" x 0.28" (51mm x 23mm x 8mm) without headers soldered in  Light as a (large?) feather ‐ 5.7 grams  ATmega32u4 @ 8MHz with 3.3V logic/power  3.3V regulator with 500mA peak current output  USB native support, comes with USB bootloader and serial port debugging  You also get tons of pins ‐ 20 GPIO pins  Hardware Serial, hardware I2C, hardware SPI support  8 x PWM pins  10 x analog inputs  Built in 100mA lipoly charger with charging status indicator LED  Pin #13 red LED for general purpose blinking  Power/enable pin  4 mounting holes  Reset button  The Feather 32u4 Bluefruit LE uses the extra space left over to add our excellent Bluefruit BTLE module  + two status indicator LEDs.  The Power of Bluefruit LE  The Bluefruit LE module is an nRF51822 chipset from Nordic, programmed with multi‐function code  that can do quite a lot! For most people, they'll be very happy to use the standard Nordic UART RX/TX  connection profile. In this profile, the Bluefruit acts as a data pipe, that can 'transparently' transmit  back and forth from your iOS or Android device. You can use our iOS App or Android App, or write your  own to communicate with the UART service.  The board is capable of much more than just sending strings over the air!  Thanks to an easy to learn AT  command set, you have full control over how the device behaves, including the ability to define and  manipulate your own GATT Services and Characteristics, or change the way that the device advertises  itself for other Bluetooth Low Energy devices to see. You can also use the AT commands  to query the  die temperature, check the battery voltage, and more, check the connection RSSI or MAC address, and  tons more. Really, way too long to list here!  Use the Bluefruit App to get your project started  With our Bluefruit iOS App or Android App, you can quickly get your project prototyped by using your  iOS or Android phone/tablet as a controller. We have a color picker,  quaternion/accelerometer/gyro/magnetometer or location (GPS), and an 8‐button control game pad.  This data can be read over BLE and piped into the ATmega32u4 chip for processing & control  You can do a lot more too!  o o o o The Bluefruit can also act like an HID Keyboard (for devices that support BLE HID)  Can become a BLE Heart Rate Monitor (a standard profile for BLE) ‐ you just need to  add the pulse‐detection circuitry  Turn it into a UriBeacon, the Google standard for Bluetooth LE beacons. Just power it  and the 'Friend will bleep out a URL to any nearby devices with the UriBeacon app  installed.  Built in over‐the‐air bootloading capability so we can keep you updated with the  hottest new firmware. Use any Android or iOS device to get updates and install them.  This will update the native code on the BLE module, to add new wireless capabilities,  not program the ATmega chip.  Comes fully assembled and tested, with a USB bootloader that lets you quickly use it with the Arduino  IDE. Also comes with stacking headers pre‐soldered, so you can plug right into a solderless breadboard  and stack a FeatherWing. See here for the unsoldered version. Lipoly battery and MicroUSB cable not  included (but we do have lots of options in the shop if you'd like!)  Technical Details Pinout Datasheet, MDBT Datasheet, schematic, EagleCAD PCB files, and Fritzing available in the product  tutorial   https://cdn‐learn.adafruit.com/downloads/pdf/adafruit‐feather‐32u4‐bluefruit‐le.pdf  Product Dimensions: 51.2mm x 22.8mm x 19.2mm / 2.0" x 0.9" x 0.8"   Product Weight: 8.5g / 0.3oz        https://www.adafruit.com/product/3242 10‐30‐17
很抱歉,暂时无法提供与“3242”相匹配的价格&库存,您可以联系我们找货
  • 1+276.659801+35.23620
    • 1+288.24450
