USB Micro B Cable with Data/Charge Sync
Switch
PRODUCT ID: 3439
Description
Your cell phone charges off of USB, but can you really trust that charging station at the airport? Now you
can control when to allow data in or out of your device with this little USB extension cable. It can be used
with any device that has a micro USB port, which is like just about anything except for Apple devices.
Voila! Your cable's data lines can now be switched on or off.
Not only is it great for privacy and security concerns, it's also good for use with devices that
automatically sync when you plug them into a computer. With the data lines off, you can use it while it
charges. This is the most useful thing you never knew you needed!
It is super easy to use. Comes with a micro-B USB connector on one end and a USB A plug on the other. In
between is an in-line switch that you can set to either "Data" or "Charger". When Data is set, both D+ and
D- data lines pass through. When Charger is set, they are both disconnected.
This cable will also work with anything that has a standard micro USB port. We also have a version that is
a little USB extension cable, so it will work with an Apple lighting cable, or any other non-Micro USB
cable.
Please note: Devices don't like it when the data lines mysteriously appear and disappear. We recommend
setting the cable function and then plugging in your device.
Technical Details
o
Cable length end-to-end: 41" / 1,041mm
Engineered in NYC Adafruit ®https://www.adafruit.com/product/3439 5‐1‐17
很抱歉,暂时无法提供与“3439”相匹配的价格&库存,您可以联系我们找货
