Arcade Button with LED - 30mm
Translucent Yellow
PRODUCT ID: 3488
Description
A button is a button, and a switch is a switch, but these translucent arcade buttons are in a class of
their own. Particularly because they have LEDs built right in! That's right, you'll be button‐mashing
amidst a wash of beautiful light with these lil' guys. They're the same size as common miniature arcade
controls, and they require a 30mm diameter hole for mounting. Thus, they are sometimes referred to
as 30mm diameter.
The buttons screw in place, so you can use with up to ~15mm thick material, and will cover up if the
hole if it isn't perfectly round and clean. The action is smooth, without a strong click, yet you can
definitely feel when the button is pressed. A tiny micro‐switch is pre‐installed with gold plated
contacts.
Even unlit, they look fantastic: all of the colors have a crystal translucent glossy look. As noted they
have two surface mount LEDs with resistors built in, buried in the button body. Next to the switch
contacts are two additional contacts for powering/controlling the LEDs. The two LEDs are connected in
series with a ~1K resistor, so you can power the LED from a microcontroller pin or direct from 5V (say
USB) with 5mA draw.
Note that the Red and Yellow versions of these LED buttons cannot run at 3.3V because the LEDs are in
series! 5V or higher is required.
This is the 30mm Translucent Yellow version of our LED arcade buttons.
Technical Details
o
o
Supply Voltage: 5V @ 10mA
Weight: 12.5g
https://www.adafruit.com/product/3488 10‐17‐17
很抱歉,暂时无法提供与“3488”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+28.284151+3.42245
