3565
    ADAFRUIT
    SOLDERING STATION 50W 1 CH 110V
3565 数据手册
      ATTEN 50W 110V Soldering Station - AT937 PRODUCT ID: 3565     Description This compact but 50W‐powerful stationary soldering iron is a great entry‐level soldering station, and  we've been using it around Adafruit for soldering with a lot of success. It's not much more expensive  than the chunky 'all in one" irons, but comes with a separate power supply and pen. Heats up fast and  solders both lead and lead‐free solder like a champ!  The powering station is equipped with a temperature control knob lock. After setting the desired  temperature, tighten the hex nut on the underside of the knob mount using the supplied hex wrench.  Turn the nut clockwise to tighten the knob lock. The heater light blinks on and off when the iron tip  reaches the set temperature.  Please note that it comes with a blunt conical tip which is good for bigger through‐hole parts. We  found its OK for beginner projects but you'll likely want to pick up some alternative tips. You can use  any "Hakko style" soldering tips to quickly change from through hole to SMT to drag‐soldering and  back. We strongly recommend picking up a screw‐driver style tip for better THM results, and a fine‐ point tip for SMT work.  The included metal iron holder provides a safe way to put aside your soldering iron while still hot, and  also includes a cleaning sponge with sponge tray. With proper care it will last for many years. Turn it  off when not in use and clean the plated tip with a slightly damp sponge (no filing or sanding!)  Includes:  o o o o Station/receptacle  Soldering iron (ATTEN907)  ATTEN iron holder with cleaning sponge  Instruction manual  Plug is 110 US‐style and can only be used in 110V countries! Do not attempt to use a plug‐converter  with this soldering iron to use in 220V countries.    Technical Details o o o o o o o o o Power Voltage: 110V AC / 60Hz  Power Consumption: 50W  Temperature Range: 200 ~ 480°C / 392 ~ 896°F  Tip Leakage Voltage:
很抱歉,暂时无法提供与“3565”相匹配的价格&库存,您可以联系我们找货
