Adafruit MetroX Classic Kit Experimentation Kit for Metro 328
PRODUCT ID: 3588
Interested in making neat stuff with an Arduino-compatible board but not sure
where to start? This kit includes all the pieces needed to complete over 20
different circuit and projects. Basically everything you need to be playing within
minutes of its arrival. No soldering required, works with Mac, Windows and
Linux!
This item is the same exact kit as https:// www.adafruit.com/product/170
This pack includes the Adafruit Metro. METRO is the culmination of years of
playing with AVRs: we wanted to make a development board that is easy to use
and is hacker friendly. At the heart is an ATmega328P, with 32KB of flash and
2KB of RAM, running at 16 MHz. It is fully compatible with the Arduino IDE
(select "Arduino UNO" in the board-type menu)
Power the METRO with 7-9V polarity protected DC or the micro USB
connector to any 5V USB source. The 2.1mm DC jack has an on/off switch
next to it so you can turn off your setup easily. The METRO will
automagically switch between USB and DC.
METRO has 19 GPIO pins, 6 of which are Analog in as well, and 2 of which
are reserved for the USB-serial converter. There's also 6 PWMs available
on 3 timers (1 x 16-bit, 2 x 8-bit). There's a hardware SPI port, hardware
I2C port and hardware UART to USB. Logic level is 5V but by cutting and
soldering closed a jumper, you can easily convert it to 3.3V logic
USB to Serial converter, there's a hardware USB to Serial converter that can
be used by any computer to listen/send data to the METRO, and can also
be used to launch and update code via the bootloader
Four indicator LEDs, on the front edge of the PCB, for easy debugging.
One green power LED, two RX/TX LEDs for the UART, and a red LED
connected to pin PB5
Easy reprogramming, comes pre-loaded with the Optiboot bootloader,
which is supported by avrdude and only uses 512 bytes.
Fully compatible with the Arduino IDE (select "Arduino UNO" in the boardtype menu)
Works with all Adafruit shields!
If you're an educator looking to order more of this product than we have in
stock, please email educators@adafruit.com!
Features:
20+ online circuits to explore microcontroller basics. Covering LEDs,
transistors, motors, integrated circuits, pushbuttons, variable resistors,
photo resistors, temperature sensors & relays.
Comes with an Adafruit Metro prototyping bundle to make constructing
your circuits and future projects easy.
Includes:
Arduino Prototyping Bundle (the latest Adafruit Metro, half size
breadboard & acrylic holder)
65 Piece Jumper Wire Bundle
Full color printed 32-page Experimenter's Guide
13 color Breadboard Layout Sheets
USB Cable
9V battery clip
Micro Servo
DC Toy Motor
Mini Remote Control
16x2 LCD + extras
Force Sensitive Resistor
Loads of components:
1x 10K Pot
1x Piezo Buzzer
3x 10K 5% Resistors
3x 2.2K 5% Resistors
2x IN4001 Diode
1x 5V Relay
1x TMP36 Temperature Sensor
25x 560ohm 5% Resistors
1x 74HC595 Chip
3x Extra-long Servo Pin
1x Headphone Jack
2x PN2222
1x 220uF / 6.3V Electrolytic Capacitor
16-pin Male Header
2x 12mm Tactile Switch
1x IR Sensor
1x HW-5P-1 Light Sensor
1x 5mm IR LED
1x Diffused RGB LED
1x Diffused 10mm Blue LED
10x Diffused Red 5mm LED
10x Diffused Green 5mm LED
https://www.adafruit.com/product/3588 4‐3‐18
很抱歉,暂时无法提供与“3588”相匹配的价格&库存,您可以联系我们找货
