3632
    ADAFRUIT
    操纵杆 人机接口 羽毛 平台评估扩展板
3632 数据手册
  Adafruit Joy FeatherWing for all Feathers PRODUCT ID: 3632         Description Make a game or robotic controller with this Joy‐ful FeatherWing.This FeatherWing has a 2‐axis joystick  and 5 momentary buttons (4 large and 1 small) so you can turn your feather board into a tiny game  controller. This wing communicates with your host microcontroller over I2C so it's easy to use and  doesn't take up any of your precious analog or digital pins. There is also an optional interrupt pin that  can alert your feather when a button has been pressed or released to free up processor time for other  tasks.  This FeatherWing features Adafruit Seesaw technology ‐ a custom programmed little helper  microcontroller that takes the two analog inputs from the joystick, and 5 button inputs, and converts it  into a pretty I2C interface. This I2C interface means you don't 'lose' any GPIO or analog inputs when  using this 'Wing, and it works with any and all Feathers! You can easily stack this with any other  FeatherWing because I2C is a shared bus. If you have an I2C address conflict, or you want to connect  more than one of these to a Feather, there are two address‐select jumpers so you have 4 options of I2C  addresses  There's an optional IRQ (interrupt) line that you can use if you'd like the Wing to let you know when a  button has been pressed. Since its optional (and most Feathers are perfectly happy polling the Wing for  data) we left a bunch of solder jumpers so you can select what pin has the IRQ on it. Or just leave it  disconnected!  We have an Adafruit Seesaw library for Arduino, Python and CircuitPython so you can get started with  the Joy FeatherWing in a jiffy.  Comes with one assembled and programmed Wing, and two pieces of 0.1" header. Some soldering is  required to attach the headers to the FeatherWing.  Technical Details Uses I2C address 0x49 ‐ can be changed to 0x4A, 0x4B or 0x4C  Product Dimensions: 50.0mm x 23.0mm x 14.5mm / 2.0" x 0.9" x 0.6"   Product Weight: 7.3g / 0.3oz        https://www.adafruit.com/product/3632 10‐17‐17
很抱歉,暂时无法提供与“3632”相匹配的价格&库存,您可以联系我们找货
