Adjustable 60W Pen‐Style Soldering Iron ‐ 120VAC
USA Plug ‐ BEST 102C
PRODUCT ID: 3685
Description
You re‐work hard all day, so treat yourself with the BEST portable Adjustable Soldering Iron we
carry! OK, "Best" may be subjective, but it's also the name of the brand, so there ya go! But, seriously
folks, this is a really nice iron, good enough for every‐day use. We dig the slim pen iron (so comfortable
to hold), adjustable‐temperature (oooh there's a little control box!), durable grounded cord, and fast
60 Watt heat up!
When you don't need a full soldering 'battle station', this pen‐type iron will work well, either on a
bench‐top or in a tool box. It can handle any task you throw at it, and the handy control box sets the
temperature. Once the soldering is complete and the iron has cooled off, you can easily coil it up to
keep your work space clean and tidy.
This soldering iron has an adjustable temperature range from 280ºC to 480ºC. For most lead‐free
soldering, try 400°C. For lead‐based solder, 350°C will do. Adjust as necessary! It may not be as
powerful or easy‐to‐use as the full stand‐up Hakko, but it is a lot more portable. We also carry a
soldering iron stand (and a deluxe model as well) in case you want to keep it from rolling around your
desk.
Best of all, you can use this iron with Hakko tips. The tip it comes with is a nice general‐purpose conical
tip for all through‐hole and larger‐SMT work. But if you want to spice things up, grab any Hakko tip and
swap it out once the iron has cooled down.
Technical Details
o
o
o
o
o
o
Voltage: AC 110V USA plugs
Temperature Control: 280ºC ~ 480ºC
Power: 60W
Cable Length: Approx. 130cm
Insulation Resistance: > 100mΩ
Capacitance:
很抱歉,暂时无法提供与“3685”相匹配的价格&库存,您可以联系我们找货
