3688
    ADAFRUIT
    存储卡 - 扩展件
3688 数据手册
          Micro SD Card Extender ‐ 68cm (26 inch) long  cable  PRODUCT ID: 3688   Description  Stop fiddling with SD card sockets in the back of your latest gadget, and streeeeeeeeeetch out with a  Micro SD Card Extender . This simple, but effective device gives you a long flexible cable, a psuedo  Micro SD card on one end, and a matching micro SD card socket on the other. Plug in the card half and  attach the socket wherever you like. This is a great hack for length constraints with 3D printers, single‐ board computers, data‐logging kits and more. Get to your micro SD card in and out and safeguard  against wear and tear.  The sockets are push‐push. Insert the card in to lock, and press in again to release it.  There's a wee  pictogram on the socket which shows the correct orientation. We used this with a Replicator 3D printer  (using an adapter), various Feathers, and also a Raspbery Pi 3 Linux computer and it was speedy and  error free, but it is a hack, so be aware that high‐speed and high‐noise environments may end up not  working.  Note: Micro SD Card not included  Technical Details  Cable Length: 68cm / 26"  Product Weight: 10.2g / 0.4oz        https://www.adafruit.com/product/3688 1‐15‐18
很抱歉,暂时无法提供与“3688”相匹配的价格&库存,您可以联系我们找货
    • 1+60.90727
    库存:96
