Panel‐Mount Banana Jacks 4mm ‐ Pack of 5 Multi‐
Color
PRODUCT ID: 3691
You've done such a great job making your own electronic control panel that the last thing you need are
those wires to get pulled out and frizzy. These fancy Panel‐Mount Banana Jacks look good and work
well. They will snugly hold onto any 4mm banana plug or cable, and have a colorful ring you can use to
help identify and categorize connections.
Each plug has an M8 screw body with a washer+nut combination that can be used to secure it to a
panel. The back has a large slug with a hole you can solder to.
Comes as pack of 5, you get one of each lovely color. We also have Solder‐free Stackable Banana Plugs
that go well with these jacks.
Technical Details
o
o
o
o
o
o
o
Body: Nickel‐plated brass
Insulator: PA66 Nylon
Voltage: up to 30V AC ‐ 60V DC
Current: up to 15A
Weight (single jack): 4.2g
Internal diameter: about 4.8mm
Length: about 28mm
https://www.adafruit.com/product/3691 1‐23‐18
很抱歉,暂时无法提供与“3691”相匹配的价格&库存,您可以联系我们找货
