Chibi Clip
PRODUCT ID: 3698
DESCRIPTION
An essential companion to the Chibi Chip, the Clip enables quick testing and re‐use of the Chip.
With the Clip, attaching (and detaching) your Chip to circuits built on paper is as easy as sealing
a bag of chips. You can design your paper electronics project on stiff paper using conductive
tape or paint, then clip the Chibi on to make the magic happen.
When designing copper tape patterns to work with the Clip, it’s recommended to use the Chip
as a marker on the paper’s edge where the copper tape should go, before laying out the copper
tape. Run the tape all the way to the edge of the paper, and make sure the tape is as smooth as
you can make it. Large wrinkles will get in the way of a Clip‐mounted Chip from connecting on
all the pieces of copper tape.
Keep in mind the Chibi Chip is sold separately from the Chibi Clip (but we stock it in the shop so
just pick up both!) You’ll need to insert the Chip into the Clip following the step‐by‐step
instructions printed on the back of the box, and then you’re ready to rock!
Chibitronics is collaboration between bunnie Huang and Jie Qi . Jie is a PhD student at the MIT
Media Lab and her research is all about combining arts and crafts with electronics and
programming. bunnie is the Director of Studio Kosagi and a hacker who designs and
manufactures hardware.
TECHNICAL DETAILS
Product Weight: 15.8g / 0.6oz
https://www.adafruit.com/product/3698 1‐9‐18
很抱歉,暂时无法提供与“3698”相匹配的价格&库存,您可以联系我们找货
