Proto-pasta - 2.85mm Diameter Conductive Graphite Filament - 500g
PRODUCT ID: 3752
Pici up this filament today! It'd be Fusilli not to buy this filament! We
can't tagliatelle you enough about this filament. Are these puns Spirali-ng out of
control?
Sorry! We had to get that out of our system. Proto-pasta's fun packaging makes
us hungry for Italian food. If you're hankering for unusual and unique material
filaments, we've got a new spool of noodles for you!
This Proto-pasta 2.85mm diameter 500 grams of filament in Conductive
Graphite opens up a new world of 3D-printed fun but with electronics!
Proto-pasta Conductive PLA is an FFF/FDM filament, so now you can print circuit
assembles with touch or light sensors or LEDs to your gamut of 3D printed
creations!
And, of course, even though it has the word "Pasta" in the name, it's not for
eating.
Check out the Proto-pasta site here for more info and frequently asked
questions about this filament!
This filament performs best extruded between 195°C and 225°C.
Features:
Solid, weighted feel with 1.5x the density of standard PLA
Attracts magnets (neodymium type recommended for strongest attraction)
Induction at magnetic saturation about 0.15 Tesla
Relative (to air) permeability - between 5 and
8 independent of frequency up to 1 MHz
Permeability - between 62E-7 and 100E-7
H/m independent of frequency up to 1 MHz
More thermally conductive
Prints like PLA with less nozzle wear 'n tear
TECHNICAL DETAILS
Resistivity:
Volume resistivity of molded resin (not 3D Printed): 15 ohm-cm
Volume resistivity of 3D printed parts along layers (x/y): 30 ohm-cm
Volume resistivity of 3D printed parts against layers (z): 115 ohm-cm
Resistance of a 10cm length of 2.85mm filament: 600ohm
Bed Temp (if available, is not required): 50°C
Hot End Temp: 215 – 230°C (Proto-pasta runs it on the hotter side to encourage
layer adhesion)
Performance:
Strength: Fair strength. More flexible than PLA, but less layer adhesion
Stiffness: Low, semi-flexible
Heat Resistance: Similar to PLA, use below 50ºC
Layer Adhesion: Fair layer adhesion. Not as good as normal PLA
Flexibility: Filament is quite flexible but will break if bent repeatedly
(particularly 2.85mm). Printed parts are rigid if more than a mm or two
thick. Thin sections are somewhat flexible but fail along layer lines if
flexed more than a few times.
Failure Mode: If flexed to breakage, failure will be along layer lines.
Warping: Very low warping
Dual-Head compatibility: Compatible with (sticks to) PLA in dual material
prints
Proto-pasta Conductive PLA is a compound of Natureworks 4043D PLA, a
dispersant and conductive carbon black. In filament form, it is very flexible, and
is compatible with any PLA printing printer.
https://www.adafruit.com/product/3752 3-12-18
很抱歉,暂时无法提供与“3752”相匹配的价格&库存,您可以联系我们找货
