Ball Top 4-Way Rocker Switch
PRODUCT ID: 3758
The super-villain emerges from the grand entrance in a wicked, souped-up
robotic spider. "Ah hah, so you've discovered my secret compound, Ms. Croft.
How unfortunate for you that I control all the egresses..." She chortles (evilly)
and presses forward on the switch installed on her armrest panel.
"Before I modded my robotic contraption, I could only go backwards and
forwards. Now as you can see, I enjoy greater directionality with this Ball Top 4Way Rocker Switch. Resembles an arcade joystick, does it not, Ms. Croft? Never
has leading you to your doom felt more like a game!"
This is a very nice, hefty 4-way control switch, it looks a lot like a joystick but is
decidedly heftier, and has built in clamping-switches rather than using
microswitches. This makes it great for really big robotics and control panels, but
it's not as light and easy to use as a plain joystick. Also it has built in X retaining
slots so you really can only move in four directions, you can't rotate around
once you've picked a direction like an arcade stick. You can easily disassemble
the switch enough to panel mount it, there are even a few gasket rings included.
This way or that way, one or the other, perhaps or perhaps not! So hard to make
decisions these days without feeling like you're just going back and forth
constantly. Deciding how to use this joystick-looking rocker switch? That's the
easiest decision you'll make all day!
Dimensions:
Weight: 180g / 6.3oz
Overall length: ~145mm / 5.7"
Base: 51 x 51mm / 2" x 2"
Switch current: 4 Amp
Switch voltage: 250V
Ambient operating temperature: -25ºC – 45ºC
Operation handle declination: 30º
Product Weight: 180.0g / 6.3oz
Datasheet
https://www.adafruit.com/product/3758 4-17-18
很抱歉,暂时无法提供与“3758”相匹配的价格&库存,您可以联系我们找货
