Adafruit 1.54" 240x240 Wide Angle TFT
LCD Display with MicroSD - ST7789
PRODUCT ID: 3787
We've been looking for a display like this for a long time - it's only 1.5" diagonal
but has a high density 220 ppi, 240x240 pixel display with full-angle viewing.
It looks a lot like our 1.44" 128x128 display, but has 4x as many pixels and
looks great at any angle. We've seen displays of this caliber used in
smartwatches and small electronic devices but they've always been MIPI
interface. Finally, we found one that is SPI and has a friendly display driver, so it
works with any and all microcontrollers or microcomputers!
This lovely little display breakout is the best way to add a small, colorful and
very bright display to any project. Since the display uses 4-wire SPI to
communicate and has its own pixel-addressable frame buffer, it can be used
with every kind of microcontroller. Even a very small one with low memory and
few pins available! The 1.54" display has 240x240 16-bit full color pixels and is
an IPS display, so the color looks great up to 80 degrees off axis in any
direction. The TFT driver (ST7789) is very similar to the popular ST7735, and
our Arduino library supports it well.
Our breakout has the TFT display soldered on (it uses a delicate flex-circuit
connector) as well as a ultra-low-dropout 3.3V regulator and a 3/5V level
shifter so you can use it with 3.3V or 5V power and logic. We also had a little
space so we placed a microSD card holder so you can easily load full color
bitmaps from a FAT16/FAT32 formatted microSD card. The microSD card is not
included, but you can pick one up here.
Of course, we wouldn't just leave you with a datasheet and a "good luck!" we've written a full open source graphics library that can draw pixels, lines,
rectangles, circles, text and bitmaps as well as example code and a wiring
tutorial. The code is written for Arduino but can be easily ported to your favorite
microcontroller!
Specifications:
1.54" LCD TFT display
Built-in microSD slot
1x16 header for easy breadboarding
4 x 0.1" / 2.5mm mounting holes in corners
LCD screen dimensions: 32mm x 31mm / 1.3" x 1.2"
Overall dimension: 42mm x 41mm x 6mm / 1.7" x 1.6" x 0.2"
Mounting holes: 1.45" x 1.4"
Weight: 8.7g
https://www.adafruit.com/product/3787 4‐17‐18
很抱歉,暂时无法提供与“3787”相匹配的价格&库存,您可以联系我们找货
