Arcade Button and Switch Quick-Connect
Wires - 0.187" (10-pack)
PRODUCT ID: 3835
Quick connector wire sets make wiring up our arcade-style or metal buttons
quicky-quick. Each wire comes as a 'pair' with two 0.187" quick-connects precrimped. The wires are terminated together in a JST 2.5mm 2-pin connector.
This connector will fit in 0.1" headers, so it's breadboard compatible or you can
stick two wires into the end. Of course, you can chop this off if there's no use
for it.
If you need a connector for the other side, try this JST XH (matching part from
Digi-Key here)
https://www.digikey.com/products/en?x=0&y=0&lang=en&site=us&KeyWords=455-2247-ND
We've found these work with our:
Massive Arcade Buttons (switch contacts only)
Large Arcade Buttons (switch contacts only)
Micro Switches (Except for #820, the one with the long wire)
But they are not compatible with the LED contacts Massive and
Large Arcade buttons. For those, you'll want the 0.25" Arcade/Button QuickConnect Wire Pairs. We also have 0.11" Quick-Connects.
We've also noticed that while these are the right size, they may be a little loose
on some switches. You can crimp them a little more with a pair of pliers to get a
better grip!
TECHNICAL DETAILS
Wire length (including connectors): 212mm / ~8.3"
https://www.adafruit.com/product/3835 8‐6‐18
很抱歉,暂时无法提供与“3835”相匹配的价格&库存,您可以联系我们找货
