4x4 Matrix Keypad
PRODUCT ID: 3844
Punch in your secret key (or Jenny's number) into this numeric matrix keypad.
This keypad has 16 buttons, arranged in a telephone-line 4x4 grid. The keys are
connected into a matrix, so you only need 8 microcontroller pins (4-columns
and 4-rows) to scan through the pad. Check the tutorials tab for links to an
Arduino library and example code.
We include some header so you can plug this into a breadboard with ease, some
light soldering is required to attach it. Or you can use plain wires if you like.
There's a great Matrix Keypad Arduino library that should work great with this
item with minor adjustments. It's basically a sturdier version of our Membrane
3x4 Matrix Keypad. Starting from the left there are four row pins, and then to
the right are the four column pins.
If you dig our demo, check out the Adafruit FeatherWing OLED - 128x32 OLED
We also have a 3x4 version of this matrix keypad
TECHNICAL DETAILS
Force: 160-180g
Contact Resistance:
很抱歉,暂时无法提供与“3844”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+49.958301+6.06600
