Adafruit NeoPixel UV LED Strip with 32
LED/m - White PCB - 1M
PRODUCT ID: 3851
What new iteration of NeoPixel strip is this? Roll out the black light and disco
ball! It's an Adafruit NeoPixel Ultraviolet Strip with 32 LEDs per meter! Each
order comes as a single one meter long strip. If you order multiple meters, you'll
get that many individual 1 meter pieces.
The strip is made of flexible PCB material, and comes with a weatherproof
sheathing. You can cut this stuff pretty easily with wire cutters. There are cut-
lines every 3cm (1 LED each). Solder to the 0.1" copper pads, and you're good to
go. We have a 5V/2A supply that should be able to drive 1 or more
meters (depending on use) and a 5V/10A supply that can drive 5 meters (or
more, if you are not lighting up all the LEDs at once) You must use a 5V DC
power supply to power these strips; do not use higher than 6V, or you will
destroy the entire strip. Yikes!
Comes with a 2-pin JST SM connector on each end.
To wire up these strips we suggest picking up some JST SM plug and
receptacle cables. Please note, we try hard to get consistent wiring between
batch of strip but we can't guarantee it. Please double check which side is the
input and which is the output by looking at the strip for the directional arrows
and pin labeling.
You can use these with any 'NeoPixel' or WS2812 driver (FastLED, etc). The R, G
and B channels translate to the three individual UV diodes. So we recommend
you pretty much just set all three channels to the same value, ranging from (0,
0, 0) to (255, 255, 255) to change the brightness of the three UV LEDs inside
each 5mm x 5mm package.
TECHNICAL DETAILS
https://www.adafruit.com/product/3851 8‐6‐18
很抱歉,暂时无法提供与“3851”相匹配的价格&库存,您可以联系我们找货
