NeoPixel RGB Neon-like LED Flex Strip
with Silicone Tube - 1 meter
PRODUCT ID: 3869
No joke, we have been looking for this exact product for over 5 years, and we've
finally got the perfect one in stock! You love NeoPixels, and you love silicone
diffusion? Peep this NeoPixel RGB Neon-like LED Flex Strip with Silicone Tubing!
OK its a bit of a mouthful but check out the beautiful pics! It looks a lot like
neon, but without the need for expensive transformers, glass tubing, inert
gasses, or a Las Vegas casino license. They look incredible, are super easy to
use, and are a great way to make your projects light up!
It's flexible and bendy with a solid chunk of translucent silicone rubber as a
diffuser.
The silicone makes for a strong, durable weather-proof casing. While not
guaranteed for dunking underwater or long-term outdoor exposure, they're
durable enough for projects that have to survive the outdoors, like cosplay, bike
lighting or festival decorations. You can cut this stuff with wire cutters.
You'll get 1 meter long tube that is sealed at one end, and has a JST SM 3 pin
connector in the input. Provide 9V (will work) to 12V (ideal) on the power pins,
and provide your standard issue NeoPixel (WS281x) data on the third pin - don't
forget to share the ground pin between the12V power supply and your
microcontroller. Boom - you're glowin' in style. For fixed installations, For
portable use, try our 8 x AA battery packs with NiMH rechargeable or Alkaline
batteries. For fixed installs, this 12V 1A adapter will work great. then pick up a
JST 3 SM connector set here for quick installation
This strip contains 60 LED along the meter but in groups of 3-LEDs-per-
pixel. So basically, in your NeoPixel program, this looks like a 20-pixel-long
strand.
Our detailed NeoPixel Uberguide has everything you need to use NeoPixels in
any shape and size. Including ready-to-go library & example code for Arduinos,
CircuitPython and Raspberry Pi
TECHNICAL DETAILS
Power: 10W/M
Voltage: DC12V
LED: SMD 5050
LED Driver Chip: WS2811/RGB
Weatherproof Rating: IP65
Wiring: Red DC12V, Green Data in 5V logic, Black GND
Length: 105mm
Width: 12.5mm
Height: 22mm
Product Dimensions: 1,000.0mm x 22.0mm x 12.5mm / 39.4" x 0.9" x 0.5"
Product Weight: 300.5g / 10.6oz
https://www.adafruit.com/product/3869 9‐7‐18
很抱歉,暂时无法提供与“3869”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+395.875191+47.84585
