3871
    ADAFRUIT
    GEARMOTOR 300 RPM 3-3.7V MINI
3871 数据手册
        Mini Geared Pager Motor with Return Spring PRODUCT ID: 3871 These are very unusual motors, but we thought they could be handy for projects that need a small geared-down motor. At the core is a 'pager motor' - a small thin DC motor that runs on about 3VDC. That motor is then geared down inside the red-plastic body of the motor. Finally, the output axle is connected to a plastic triangle that has a bent-wire return spring. There are two plastic stops built into the outside of the motor. If you keep the plastic triangle attached to the motor, you can 'swing' the motor back and forth by applying forward or backwards voltage. The switch ranges about 60 degrees from center (120 degrees total). If you remove power, the self-centering spring will bring the triangle back to center. You can also remove the triangle piece and, as you can see in our animation above, you get a normal rotating axle which you can use for rotating something small. Like we said, they're unusual motors, but they're also inexpensive and unique - you may find a good use for them! Comes 1 per order TECHNICAL DETAILS        At Nominal Voltage: DC 3V / Speed: 245 RPM No-load current: 45mA Stall current: 380mA At Nominal Voltage: 3.7V / Speed: 300 RPM No-load current: 57mA Stall current: 500mA External shaft: 3.5 x 3.5mm Leads: approx 330mm Weight: 3g        https://www.adafruit.com/product/3871 9‐5‐18
很抱歉,暂时无法提供与“3871”相匹配的价格&库存,您可以联系我们找货
