3881
    ADAFRUIT
    ROTATING DOOR LOCK DC MOTOR
3881 数据手册
        Rotating Door Lock DC Motor PRODUCT ID: 3881   Adding to our collection of somewhat specialized motors, this Rotating Door Lock Motor is a DC Gearbox motor with a little pocket that is intended for a door look mechanism. The motor only turns 90 degrees clockwise or counter- clockwise and will stall (but not strip) if you try to keep running it past the angle. It's geared down so it has high torque, but that also makes it slow - it is about 5 seconds for it to rotate 'closed' or 'open'. That said, we like that you can power it from approximately 5V so its easy to hook up to your microcontroller or computer using Crickit and Arduino, CircuitPython or MakeCode. Constructed with four mounting holes and runs quietly. We don't have any more specs or documentation for this beast. TECHNICAL DETAILS  Rated Voltage: 5 VDC  No Load Current: 30mA  Stall Current: 400mA  Gearbox ratio: Approx 1:2000  Weight: 60 g  Wire Leads: approx 70mm long        https://www.adafruit.com/product/3881 9‐7‐18
很抱歉,暂时无法提供与“3881”相匹配的价格&库存,您可以联系我们找货
    • 1+21.88796
