389
    ADAFRUIT
    MINI REMOTE CONTROL
389 数据手册
      Mini Remote Control PRODUCT ID: 389 This little remote control would be handy for controlling a robot or other project from across the room. It has 21 buttons and a layout we thought was handy: directional buttons and number entry buttons. The remote uses the NEC encoding type and sends data codes 0 thru 26 (it skips #3, #7, #11, #15, #19 and #23) to address #0. You can use this to control something that is expecting NEC codes or you can pair this with our IR remote receiver sensor. Comes with an included battery! Just remove the plastic pull-tab to use  TECHNICAL DETAILS  Mini remote control with 21 buttons  38KHz NEC code output, 940nm IR LED  40mm x 86mm x 7mm (3.4" x 1.6" x 0.3")  Runs on CR2032 battery, included                                https://www.adafruit.com/product/389 7‐20‐18
很抱歉,暂时无法提供与“389”相匹配的价格&库存,您可以联系我们找货
    • 1+43.30528
