Flexible Protoboard - 20cm x 30cm
PRODUCT ID: 3904
https://www.adafruit.com/product/3904#Slide4
https://www.adafruit.com/product/3904#Slide7
DESCRIPTION
Make your next project super-flexy with a biiiig prototyping board that can twist and shout– err, twist and
bend! This passive flexible proto-PCB is about large as a piece of paper, but instead of dead-trees its
made of very thin FR4.
We're not bending the truth! This protoboard is only 0.4mm thick, so its extremely bendable and you can
cut it easily with scissors - just don't use your nice fabric scissors since the fiberglass will dull them. It
has a bend radius of about 2 or 3". You can also crease it, but that might break a trace if you crease a
trace, and of course it may crack and break along the crease.
And, of course, there are 0.1" spaced prototyping holes with solder pads. Th ey aren't fully plated through,
the holes are only on one side. But, you can solder any thru-hole components to the pads. Sensors? LEDs?
Jumper wires? We have no assumptions what people are going to use it for, but we know it is going to
be awesome.
The PCB is really floppy. If you need to solder electronic components, you may need some physical
support as the protoboard won't stay 'straight' on its own. So why not octopus it up and give yourself an
extra hand (or four!) with some Hobby Creek tools?
TECHNICAL DETAILS
Material: 0.4mm FR-4 20cm x 30cm
Solder Pad Aperture: 1mm
Spacing: 2.54mm / 0.1"
Product Dimensions: 300.0mm x 180.0mm x 0.4mm / 11.8" x 7.1" x 0.0"
Product Weight: 39.0g / 1.4oz
很抱歉,暂时无法提供与“3904”相匹配的价格&库存,您可以联系我们找货
