JST PH 4-Pin to Male Header Cable - I2C
STEMMA Cable - 200mm
PRODUCT ID: 3955
This cable will let you turn a JST PH 4-pin cable port into 4 individual wires with highquality 0.1" male header plugs on the end. We're carrying these to match up with any of
our boards with 'STEMMA' connectors on them such as the Hallowing or Trellis M4. Can
also be used with any STEMMA breakouts! This one has header pins, so it could be used
to connect to socket header or breadboards.
The wires are even color coded:
Black for GND
Red for V+
White for SDA
Green for SCL
Even though this is a JST PH connector, it will fit into a Seeed Grove connector and
have the right matching wires as well.
We also stock a version with female headers on the end
For more information about JST PH connectors, visit the JST website
TECHNICAL DETAILS
Wire Length: 7.8" / 200mm
Wire Diameter: 1.6mm
JST Connector: 8.5mm
JST Pitch: 2mm
https://www.adafruit.com/product/3955 11‐19‐18
很抱歉,暂时无法提供与“3955”相匹配的价格&库存,您可以联系我们找货
