USB Micro B Male Plug to 5-pin
Terminal Block
PRODUCT ID: 3972
DESCRIPTION
Make your next custom USB cable a breeze with
a USB Micro B Male Plug to 5-pin Terminal Block.
If you need to connect to a device with a micro
USB plug or maybe make your own USB OTG
device or custom cable of sorts - this adapter will
come in very handy: no soldering required! Just
use a small screwdriver to open up the terminal
blocks, slide in your stranded or solid-core wire,
and re-tighten.
All the pins are labeled, which is really nice
because we keep forgetting the order.
A – Pin 1 (V+)
B – Pin 2 (D-)
C – Pin 3 (D+)
D – Pin 4 (ID)
E – Pin 5 (GND)
We also carry the plug 'mating' version of this
adapter.
Terminal Block Pitch: 5mm
Product Dimensions: 32.5mm x 28.0mm x
10.4mm / 1.3" x 1.1" x 0.4"
很抱歉,暂时无法提供与“3972”相匹配的价格&库存,您可以联系我们找货
