Adafruit NeoTrellis M4 with Enclosure and
Buttons Kit Pack
PRODUCT ID: 4020
So you've got a cool/witty name for your band, a Soundcloud account, a 3Dprinted Daft Punk helmet... so what could be missing from your road to
stardom? The NeoTrellis M4 Kit Pack, of course!
The NeoTrellis M4 is an all-in-one USB + NeoPixel + Elastomer + Audio board.
It's powered by our new favoritest-chip-in-the-world, the SAMD51, a Cortex M4
core running at 120 MHz. This chip has a speedy core with CircuitPython and
Arduino support, hardware DSP/floating point, dual DACs (more on that later!)
and all the goodies you expect from normal chips like I2C, ADC, DMA, etc. It has
a roomy 512KB of flash and 192KB of SRAM so it's great for CircuitPython, we
added a full 8MB flash chip so tons of space for files and audio clips. Or you can
load Arduino in for bonkers-fast audio processing/generation with our fork of
the PJRC Audio library.
The native USB port can turn it into a MIDI USB device if you like - currently
that's only supported in Arduino. Tether it to a computer or tablet, if you like.
Or use it in standalone mode, as long as its powered from a USB power plug, it'll
run whatever firmware is burned into it.
OK so you've got this big brain, but now you need inputs and outputs! There's a
4x8 grid of elastomer button pads with a NeoPixel nestled in the center of each
one. You can read any/all button presses simultaneously thanks to the fully
diode'd matrix, and also set each button color to any of 24-bit colors. (We've
even got some DMA Arduino code for the NeoPixels so that they won't take up
any processor time.) The elastomer buttons are translucent so they glow
beautifully when lit.
Time to make some noise! We picked the SAMD51 mostly because its got that
dual DAC - that's two 12-bit, 500KSPS 'true analog' outputs and we connected
them to left and right on a standard headphone jack. Since the DAC pins are
also ADC pins you could also use the left/right for audio line level input if you
so choose. You're not going to get audiophile-quality outputs from two 12-bit
DACs but you can certainly play audio clips and make beeps and bloops.
And if you want to have some audio inputs, we have you covered. The 4th pin on
the headphone jack is for microphone or line in. If you have a classic 'mobile
phone headset', the electret mic will go through an amplifier into an ADC pin.
Again, it's not audiophile quality (we're talking about an electret mic here) but
you can do audio recording and filtering on the mono input. The raw un-
amplified mic input is also connected to a DAC so you can read button presses
on headsets that have a resistor-selector for their buttons, or some other 3.3Vmax analog signal.
To add more interactivity, a precision triple-axis accelerometer from Analog
Devices, the ADXL343, is included as well, and provides sensor information on
tilt, motion, or tapping. Great for adding another dimension of data input in
addition to the button pads.
Finally, a 4 pin JST hacking port is available for extra add-ons. It's STEMMA and
Grove compatible, and provides GND, 3.3V power, and two pins that can be
used for I2C, ADC, or a UART. So connect some other sensor, or read stereo
audio in, or maybe hack together a MIDI port. Whatever you like!
Here are some of the updates you can look forward to when using NeoTrellis M4
ATSAMD51 32-bit Cortex M4 core running at 120 MHz (32-bit, 3.3V logic
and power)
Hardware DSP and floating point support
512 KB flash, 192 KB RAM
Native USB that can act as a true USB MIDI device if you like.
8 MB SPI FLASH chip for storing files and CircuitPython code storage.
4x8 elastomer pads with fully diode'd matrix - no ghosting!
4x8 NeoPixels for each pad, glows through the elastomer buttons
TRRS Headphone jack with stereo DAC outputs on Left/Right, can also be
stereo ADC inputs. Fourth pin on headphone for electret/ADC input
Built in MAX4466 electret mic amplifier for mobile phone headsets. 'Raw'
DC level reading also available on a separate ADC
4-JST hacking port with 3.3V power, ground, and two GPIO that can be
I2C/ADC/UART
Analog Devices ADXL343 triple-axis accelerometer
Really fun to press buttons and have sounds come out!
Includes:
1 x Adafruit NeoTrellis M4 Mainboard
1 x Adafruit NeoTrellis M4 Enclosure kit
1 x 2 pack of Silicone Elastomer 4x4 Button Keypad
1 x Little Rubber Bumper Feet (4 bumpers total)
This item includes Silicone Elastomer 4x4 Pads and an enclosure - you may also
want some headphones, a USB cable and maybe audio cable to go along.
https://www.adafruit.com/product/4020/1‐17‐19
很抱歉,暂时无法提供与“4020”相匹配的价格&库存,您可以联系我们找货
