13.56MHz RFID/NFC Sticker - NTAG203
Tag
PRODUCT ID: 4032
This is a blank 13.56MHz RFID/NFC Sticker with an NTAG203 chip - often used
for train/bus passes, information sharing, contactless payment, but also found
in other systems where a proximity card is desired. The tag contains a small
RFID chip and an antenna, and is passively powered by the reader/writer when
placed a couple inches away.
These can be read by almost any 13.56MHz RFID/NFC reader, but make sure it
can handle ISO/IEC 14443 Type A cards (the standard NTAG uses) as there are a
few other encoding standards (like FeLica).
These chips can be written to and store up to 144 bytes of data in writable
EEPROM divided into 4 byte banks, and can handle over 10,000 re-writes. You
can use our PN532 NFC/RFID breakout board or Adafruit NFC/RFID Shield for
Arduino to read and write data to the EEPROM inside the tag. There is also a
permanent 7-byte serial number ID burned into the chip that you can use to
identify one tag from another - the ID number cannot be changed.
These use an NTAG chipset, a 'Type 2' tag that is usable with any smartphone.
Unlike "Classic 1K" cards (a.k.a MiFare S50s), these tags are more secure and
work with almost any phone with RFID support since they avoid the patent
issues with Mifare, which requires an NXP chipset or license fee.
The sticker is 4 x 2.5cm.
TECHNICAL DETAILS
RFID chip specification:
144 bytes of user r/w memory area, divided in 36 pages (4 bytes each)
7 Byte unique identifier burned into the chip
Operating frequency: 13.56 MHz
Tag specification:
85.5mm x 54mm x 1mm / 3.36" x 2.1" x 0.03"
5.3 grams / 0.2 oz
Works about 4" away from reader
https://www.adafruit.com/product/4032/1‐8‐19
很抱歉,暂时无法提供与“4032”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+24.769201+3.15470
