Raspberry Pi Official Model 3 A+ Case
PRODUCT ID: 4096
DESCRIPTION
Keep your Raspberry Pi® Model A+ (either the original A+ or the newer 3 A+)
computer safe and snug in this solid ABS acrylic enclosure.
This case keeps your Pi secure, has labeled holes for connector access, and even
comes with four little bumper feet. You can use all of the connectors on the
edges of the Pi: HDMI, microSD slot, micro USB power, and the USB port.
This enclosure is not compatible with the Raspberry Pi Model A, B, or B+!
Be sure to check out more of our awesome Raspberry Pi accessories including:
Bare 8 GB SD card - you'll need this to load the Debian image and is not
included in a Pi computer purchase. Tested and works perfectly! We also
have a wide range of pre-burned SD cards
5V @ 2.5A Amp USB power supply - you'll need this to power the Pi using
a Micro USB cable. Tested and works perfectly with lots of power
HDMI cable - required to connect a Pi to a monitor and is not included in
Keyboards and Mice - We have a range of wired and wireless options
A wide range of accessories and essentials
Various small displays as well as nice Pi-compatible HDMI monitors in a
range of sizes, from 2.5" to 10"
Raspberry Pi A+ computer is not included, but we do stock them in the shop! No
other cables or connectors or accessories are included.
https://www.adafruit.com/product/4096/2‐5‐19
很抱歉,暂时无法提供与“4096”相匹配的价格&库存,您可以联系我们找货
