DIY USB Cable Parts - Right Angle Micro B
Plug Up
PRODUCT ID: 4104
If you love DIY cable-rigging, then these USB adapters are right up your alley!
Making custom USB cables has never been easier. Just grab one of our ribbon
cables, then swap and switch any of our USB adapters on each end using the flex
cable clips. There are options a-plenty!
This version is a USB Right Angle Micro B Plug Up only. (We also have the 'down'
version which is the opposite bend, and 'straight' version without a bend.)
Ribbon cable and other adapter not included! Check out all of the options we
have in the shop to craft your very own custom cable.
We tested out these DIY cable kits with a Circuit Playground and a computer USB
port and they worked great, even at the longer ribbon lengths, but note that
they are not going to be as durable or shielded as ready-made cables.
TECHNICAL DETAILS
PCB dimensions (excluding plug): 17 x 13.3 x 3.6mm
Plug length: 11mm
https://www.adafruit.com/product/4104/4‐15‐19
很抱歉,暂时无法提供与“4104”相匹配的价格&库存,您可以联系我们找货
