Adafruit VEML7700 Lux Sensor - I2C Light
Sensor
PRODUCT ID: 4162
Vishay has a lot of light sensors out there, and this is a nice simple lux sensor that's
easy to add to any microcontoller. Most light sensors just give you a number for
brighter/darker ambient lighting. The VEML7700 makes your life easier by calculating
the lux, which is an SI unit for light. You'll get more consistent readings between
multiple sensors because you aren't dealing with some unit-less values.
The sensor has 16-bit dynamic range for ambient light detection from 0 lux to about
120 klux with resolution down to 0.0036 lx/ct, with software-adjustable gain and
integration times.
Interfacing is easy - this sensor uses plain, universal I2C. We put this sensor on a
breakout board with a 3.3V regulator and logic level shifter so you can use it with 3.3V
or 5V power/logic microcontrollers. We have written libraries for Arduino (C/C++) as
well as CircuitPython (Python 3) so you can use this sensor with just about any kind of
device, even a Raspberry Pi!
This is Kattni's first PCB design for Adafruit, it's even signed on the back!
TECHNICAL DETAILS
Product Dimensions: 16.6mm x 16.5mm x 4.0mm / 0.7" x 0.6" x 0.2"
Product Weight: 1.0g / 0.0oz
https://www.adafruit.com/product/4162//3‐29‐19
很抱歉,暂时无法提供与“4162”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+41.561901+5.04160
- 国内价格
- 1+52.13514
- 25+50.31658
