USB C Jack to Micro USB Jack Round Panel
Mount Adapter
PRODUCT ID: 4260
If you need to add a panel-mount connection for USB C, but don't have the time
or tools to cut a custom oval or square hole, this USB C jack to USB Micro B jack
Round Panel Mount Plug is the easiest and fastest way to panel-ify your project.
It's about 30mm in diameter, so you can drill a hole in your wood, plastic or
metal with a common hole-saw or bit, no special shapes or filing required. Un-
screw the plastic nut, insert the plug and re-attach. Ta-da! Now you have a USB
C socket to USB Micro B socket adapter!
On the 'outer' side is a USB C connection. On the inside is a micro B connection.
So this is good for when your device doesnt need more than USB 2.0 speeds,
and you want to use a flexible USB-to-micro-B cable for the inner connection
but expose a USB C port. If you have a USB host device, check out this USB C to
USB A host panel mount adapter.
It's designed to easily attach to a panel up to 16mm thick (or 0.625"), or as thin
as a few mm. Perfect for adding a USB C port to your project enclosure! We like
this plug in particular for its solid body and 'forgiving' plastic lip that hides the
drill hole.
TECHNICAL DETAILS
Overall length: approx 33mm
Diameter: 30mm
https://www.adafruit.com/product/4260/7‐16‐19
很抱歉,暂时无法提供与“4260”相匹配的价格&库存,您可以联系我们找货
