Circuit Playground Proto Gizmo - Bolt-on
Perma-Proto
PRODUCT ID: 4320
Extend and expand your Circuit Playground projects with a bolt on Perma-Proto
that lets you connect solderable circuits in a sturdy and reliable fashion. This
PCB looks just like a solderless breadboard but has permanently affixed M3
standoffs that act as mechanical and electrical connections. Solder to the goldplated traces to create your custom invention!
Each pad of the Circuit Playground has a large oval pad you can connect to, and
in the center is a blue-marked Ground rail and red-marked 3.3V rail. The center
has side-connected groups, they're marked in black on top. Once you're done
you can screw on/off the Gizmo as many times as you like.
Comes with a PCB that has pre-soldered standoffs attached, and 12x M3 screws
for attachment. Fits both Classic and Express Circuit Playgrounds, but the oval
pad markings match the CPX pad naming.
TECHNICAL DETAILS
Outer Diameter: ~50.6mm / ~2.0"
Weight: 17.8g
https://www.adafruit.com/product/4320/7‐26‐19
很抱歉,暂时无法提供与“4320”相匹配的价格&库存,您可以联系我们找货
