4322
    ADAFRUIT
    多重 微型 特性 柱塞式,弹簧式
4322 数据手册
      Basic Multi-Color Micro SMT Test Hooks (6-pack) PRODUCT ID: 4322   Testing and debugging is a challenging step in board manufacturing. It can be super tricky on a fully populated PCB. So how can you test connections when you have an assortment of components blocking your probe? These Basic Micro SMT Test Hooker have solderable tabs on one end so you can attach a wire, and on the business end, a spring-actuated double-hook.They easily snap onto your project, and they're ideal for ultra-low profile surfacemount testing! Push down on the test hook, and they will attach to larger components like thru-hole parts, DIP, SOIC and such. These are not small enough for TSSOP's or TQFPs. If you need to add test points, we stock throughhole ones that fit nicely into 0.1" holes These are not the high quality ones you see that come with expensive logic analyzers - but they do get the job done. Comes 6 in a pack, one of each color. Note that you will need to solder to the tabs to use them.         https://www.adafruit.com/product/4322/9‐23‐19
很抱歉,暂时无法提供与“4322”相匹配的价格&库存,您可以联系我们找货
